Well regardless if Mikey likes Rotovac or not....I do!
There is a lot to like about Rotovac...
They make quality equipment that lasts...
They make light weight equipment that performs...
Replacement parts are readily available and priced reasonably...
I have previously written a review of Rotovac's Duel Cord CFX....
http://mikeysboard.com/forum/viewtopic.php?f=1&t=36813 after using it almost daily for 5 months ...my opinion of it has not changed....it is a great piece of equipment....in the 5 months I have used it.... the CFX has performed flawlessly...at 50 to 100 ft ...with either 1 1/2" or 2" hose it will suck almost as good as a small TM. It is tiny in size, and only weighs 40 lbs. Every TM owner should have one for a back up or to use as a Vac booster.
I do rental turnovers....cleaning really bad carpets is what I do...used with the right chems...the Rotovac original is pretty irresistable to those really soiled traffic lanes. Yes ...it is slow compared to a wand, or a
RX20....but at 28lbs you are more likely to drag it off the truck and actually use it for those stubborn areas. Want a faster powerwand? I use the Rotovac 360...cleans almost as good as the original...but easily 3 times faster....again only 28 lbs. With both powerwands ...water control is necessary...they can be supersoakers if you are not careful...which can lead to wick-back...there are always trade-offs in this business.
Both Powerwands are good tools...I really like the way that the 360 folds up....and will at some point want to trade my Rotovac Original in for a folding DHX model.
Typically I use my Duel Cord CFX, a Glided wand, a Powerwand, a "portable" Pump, and a Mytee Hot Turbo...and can bring "dead" carpets back to life. I would never consider using a 160 lb "Portable" ever again.
Thinking of hiring a female tech? My wife can carry all this light weight , truley portable equipment in and use it with ease to get excellent results on really bad carpets.
Hey Rotovac...want some advice...get with John over a Mytee and get them to produce a 200 psi , 10lb portable demand pump , and sell it in a package with your CFX, a Mytee Turbo Hot, and a Powerwand. I am using this combination daily and the results with this powerful light weight equipment is remarkable.
