In response to Art's request to help teach how to successfully HWE berber carpet, rather than pretend to with dry cleaning, I offer these pics.
You can observe the time spent with the time embedding in the pictures. Took a while but they were pleasantly surprised with the results.
Oh, btw, I had my heat setting down, temp did not get much over 200F if it even did.
Before
Vacuuming the hall and about 10ft of the main room
I went over the carpet again and recovered this soil.
Vacuumed the area between the registers
note the big black spot.
Revacuumed the area
Vacuumed this area, the LR
And the final area to vacuum, the dining room.
Applied prespray; O2 with modifier. Mixed it at 16oz/2gallons, filled a yellow tip hydroforce sprayer.
Added about 4 tblspns of Hot Sauce.
Scrubbed it in with a Whittaker CRB. You can see the difference already in the hall.
remember that black spot? Scrubbing only has removed most of it
And in the LR
and the DR. You can see a circular wear area where there was an office chair.
Finally the rinsing. HWE with 15 flow, holed glide, temp around 190F. Had the temp down for prespraying and forgot to turn it up. Prep work did most to the work. Look how clean this hall came and it stayed that way!
What black spot?!
Best way I know to clean berber, vacuum the snot out of it, then clean it.
Remove the soil and its no longer an issue.
Before
Revacuumed the area
And in the LR
What black spot?!
