Jamesh921
I have a 1.5", 2 jet, S-bend wand that I got with an EZ120 I bought about 9 years ago. When pulling the wand with the trigger engaged, it leaves about a 3 inch area down the center of the stroke that is much wetter than the outside edges of the stroke. I have back-flushed and blew air through this wand thinking that maybe it's partially stopped up. Nope, all is clear, no obstructions. I've reduced the pressure down to 250 psi and it still does the same thing. My Powermatic has plenty of vac, so that's not the problem. Any other wand I use with my machine works fine, so why does this wand leave a wet streak down the center of the stroke?
James
James
