What do you prefer??
longjo1
I have RX, Host freestyle, Host T6 and 175 side by side 2 chevy 1 tons and mounts to accomandate. I have learned that the side by side is more versitle and does a better job on trashed carpet than the RX followed by glided wand. Jim was inquireing about a new RX I would just save the extra money and go with a 175 buffer with tank takes the same time to clean and if your customer wants her t&G cleaned you can also do with confidence. Just my opinion always open to suggestions...
Jonathan
I don't keep up with what you guys talk about ....
flow.......suck.......jets........lift.........all new to me........
Although my company is growing in leaps and bounds
I am still learning a lot and know I have a long way to go.........
got a picture of a 175 with a tank ???
WISE
Jim-
The solution tank mounts to the handle/shaft and gravity feeds chemical.
floorelectricmetal.asp
WISE
Jim Nazarian
Jim Nazarian
I bought that Powerflight & its a good machine, but in the back of my mind I kept hearing a voice telling me I an OP would be better then a 175 for prescrubbing, padcappining & T/G cleaning so the 175 doesn't get much use, if your not into padcapping then a CRB\GLS\Windsor iCapsol Mini might be a consideration.
