Ryan
- Joined
- Jun 29, 2009
- Messages
- 2,415
You took a classic Steamin Demon and a kero heater. Mounted the heater in your truck, and hooked up to a standered garden hose to the heater. Then ran a hose from the heater inside to your Steamin Demon.
Using heaters like this.
http://www.northerntool.com/webapp/wcs/ ... _200377863
http://salestores.com/camspr192.html
So I think the plastic impeller (I think its called??) on the auto pump out would have to be changed out to a metal one. Any other reasons why this wouldn't work? Would the pressure from a water faucet be enough to run the water through the heater? I've never used a steamin demon so I don't know how easy/hard they are to use.
But 4gpm with 200 degree water for under 5k sounds good too me. :shock: 8) :mrgreen:
