What did they change that makes the 360i better than the original 360?
dealtimeman said:What did they change that makes the 360i better than the original 360?
John Olson" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">John Olson said:You can get the new head but the body isn't changeable. You can run a 2" hose to the machine you just need to use the right cuff to attach to the 1.5" Port. Did the 360i make the 360 obsolete? No. The 360 is a great machine if it wasn't they wouldn't have sold enough to be able to afford to keep making improvements. The adjustment mecanisim is probably the biggest change. Going to 2" isn't that big of a deal as you can still run 2" to the unit and anyone that has a 360 can change out to the new head. The adjusment knuckles do wear out but I have only had to replace one set and it is for a guy that uses the machine on EVERY Job and it took two years to wear out. He also doesn't take very good care of his equipment. He is one those guys I yell at alot, and I do mean yell at. The adjustment knuckles take 10 minutes to switch and are pretty cheap to replace. If you keep the handles tight so they don't slip and grind then I don't see them needing to be replaced for 3-4 years minumum
dealtimeman said:nate why does john have to scream at you alot?
john pm the price for the head.
and are you sure that is the only difference?
