Whats a good safe de scaler to run thru my machine?
Kevin B
Coeur D Alene ID
Kevin Bunce
Just so you know, they don't work so well if they don't run through the Heat Exchangers. I've used Prochems product with good success.
SRI Cleaning
West Chester, PA
Anthony Firmani
Glynn, Do you just mix the clear water rinse with your fresh water an run it in a normal dilution and clean carpets with it? or do you just circulate a more concentrated solution through?
