jcooper
- Joined
- Oct 7, 2006
- Messages
- 3,232
- Name
- Jerry Cooper
Couple of weeks ago unit was making too much heat and shutting down(never happened before). Descaled and cleaned filters, etc... As recommended.
Well... Now it's not making enough heat. If I put my temp gauge on max temp it will get up to 200, if I have it set in the middle, I'm cleaning at 150...
Sapphire manual lists these as causes for loss of temperature:
Temperature relief valve on water box is stuck open.
Temperature balance orifice missing
Engine RPM is low.
Defective temperature gauge.
I doubt it's the engine or gauge.
If it's the temp relief valve would it be dumping water into waste tank? Doesn't seem to be dumping.
So anyone have an idea where a temp relief valve or a Temperature balance orifice???
Thanks fellas.
Engine RPM is low.
Thanks fellas.
So, apparently an intermittent issue.
