Where is the fastest place i can get a pump clutch for my
Fort Worth , Texas
5cp-6120? are they available at autoparts stores?
on one of the trucks it is rubbing or grinding even when not activated. i believe it to be a 20mm in size.
any help would be appreciated.
John Watson
Re: Where is the fastest place i can get a pump clutch for m
I just got mine at NAPA auto parts, (in the last 2 months) Took mine in and they matched it, They have a lot of different ones to chose fromtake the old one in.
John Watson
It was about $125.00 and I believe he said it was the same clutch used on a Peterbuilt or Kenworth compresser. My problem screwed up the clutch. The way it was adapted to the shaft, somehow the adapter keyway got wallard out and caused a wabbel that screws up the clutch. I was lucky I put on a used spare first before i found out the real problem so I ony had to buy 1 new clutch..
Shane T
Waukesha, WI
Shane Tiegs
Your clutch may just need adjusting.
George V
Got my last clutch from aerotech.
think it cost twice as much as Watson's.
Fast delivery.. had it next day air.
Dallas, Texas USA
michael;
We have a used one available.
Call if you need it.
Larry
