Where to get cotton OP pads?
Johnny
La-Z-Boy
Johnny
Jeremy has micro-scrubs. John G. has Glads. Anyone got plain cotton pads?
Jeff Brown
GA
Jeff Brown
What machine are you wanting them for? Orbitec (800-528-1376) has some thick cotton terri pads that work great for a rotary, for op they work good when using them dry but when they get
really wet they will not stay on the machine. They get heavy when they absorb a lot of moisture which is why they don't stay under an op very well. but they are my first choice for a rotary.
Reactions: Johnny
Johnny
La-Z-Boy
Johnny
Thanks, Jeff. Need them for an Orbitec Brute. I'll call Clark.
Jeremy
Indiana
Jeremy
The brown ones (unbleached) or the off white ones (cotton polyester & microfiber blend)? The brown ones are great pads but like was mentioned above they only run on 1 side. Once wet the wont stick. Last I checked Clark was sold out... He may have more now though. The off white are good towels too. A bit more aggressive than the brown but not quite as durable. Way cheaper though...
The MicroScrubs are great too... Try a case.
Abigail
Western NY
Stacy
Please forgive my ignorance, and if my crazy idea is unworkable, but I'm a bit of a redneck and a tightwad.
Couldn't one sew a small group of highly absorbent towels in the size they want for a lot cheaper?
My daughters do swim and I picked up some of the $2.97 towels at wallyworld (27x52"). They are great!
It appears I can fold it over to make it sufficiently thick and then sew it and trim to fit.
I sewed some baby diapers and other thick things before and those worked well.
Again, please if this is a stupid idea, say why:) :).
Thanks!
Mardie
London Ontario,Canada
Mardie VanBree
Thanks!
Not crazy at all. It would only be crazy if you did not put lots of thought into it before you start. After all that is how they are made .
Johnny
La-Z-Boy
Johnny
I've never seen multiple-layered cotton o.p. pads. All the versions I've used over the years have been heavy single-layer with a hem.
Benton KY USA
I've done the folded towel bit many times, with the towels you mentioned. It works, but the multiple layers are hard to work with in practice.
