Jack May
That Kiwi
- Joined
- Oct 7, 2006
- Messages
- 2,423
- Name
- John
I've got/had a problem with my Genesis for almost 6 months now. The Bethels over in Aussie have been trying to help me but we're no closer to resolving the issue, rather it's been by passed so it can earn it's keep.
This machine has worked flawlessly for almost 4 years, then we started loosing water every now and again.
The water line will be hooked up, and about 1/2 hour into the job, you'd run out of water, check the water box and it'd dry... yet the supply hose is still got heaps of pressure.
This only happened from time to time and usually, disconnecting the unit, allowing a 10 minute cool down and all was right for another week or so till it hit again. This went on till the frequency got up to almost once a day and then the 10 minute cool down didn't work either.
I went through different scenarios with the Bethels and also my Pump guy and my auto electrician. After testing and cleaning different parts, I eventually over a period of a couple of months replaced the float switch unit, the dema valve and solinoid assembly complete and the fuses and the relay switch. After each step, it'd correct itself for anything from 1-3 days and then reverse back to it's old problem.
After the last 'fix' which happened to be the relay and fuses, it'll only fill on the slow speed and so for normal cleaning, you keep running out of water and have to wait for it to catch up and then you're right for another 10 minutes.
The Bethel's have sold me a small ballcock float unit to mount inside the water box and it's now working through that but I've spent over $1000 on parts and labour and still no closer to having the issue resolved.
Does anyone else have any suggestions?
John
John
