I don't normally disagree with you .but Randy is correct..............
the V is about one of the easiest machines to work on and service...........
very easy to over think.............
As I look at mine, I feel it is simpler then a slide in. I am getting ready to change the oil on mine. No different then any other van and Blueline went over everything with me until they felt satisfied I could handle it. Adam and Chuck know their business
most problems tend to be operator error and the local distributor says that they don't see them in the shop
BlueLine was very upfront and honest with me about problems some of the older units have and showed my the corrections that were made, I kind of feel they should back track and fix some of those problems
This is one reason I didn't buy a used one. The biggest problem I hear about other machines is the welds on the vac hose reel break and the fresh water tanks are not the best
the statement, "the machine can make a good cleaner into an excellent cleaner" is 100% correct
the statement, "you can clean just as well with a portable, it just takes longer" is stupid and if you really believe that then you have some serious penis envy
012 flow with 250 water is everything people say it is and with the ability to get it dry with 2 wands running at 250' each is incredible
we cleaned one of our 2x per year accounts today, fooking incredible the crap that came out of the carpet and how clean it looked even though I have done everything, in the past, that you can think of to get it cleaner
O2 juice with the booster added, soft water rinse
I insulated and carpeted my box, my machine puts out no more noise then any other TM and sounds a hell of a lot better then some lawn mower engine but if you own an older unit I would do this as well as put the rubber mat on the floor
the last thing I would say that if you think your customers don't care, some may not but quite a few of them do
I dropped it off today to put the vinyl on it
New, Proud,
Vortex owner
