prestige cleaner said:
sorry, that some of us are not gurus like yourself encapman, and never had a issue like wicking like you...
Hey Josh,
I'm sorry. I didn't mean to offend anyone. It is just less of a problem for wicking to occur on a residential carpet with good HWE cleaning.
HWE can crash and burn on CGD (commercial glue down) carpet, because there's essentially no air flow. The carpet is glued to the floor. The pile is densely packed together. You put the wand to the carpet and the flow of air through the vacuum slot is greatly restricted. And underneath the crowded tufts of fiber can be a considerable amount of soil. Spills soak all the way to the floor. And a lot of CGD carpet is olefin which wicks like a pig. Therefore wicking can easily occur on a commercial carpet.
On the other hand, residential carpet generally is fluffier and is normally installed over a pad. Hence airflow is much better in a residential setting. Plus with residential carpet there isn't quite as much olefin, although it has been increasing in recent years. So it is a lot easier to control wicking in a residential environment.
One particular residential carpet that can present more of a challenge are olefin Berber carpets. Their construction more closely resembles commercial loop carpet. And any of these common olefin Berbers can wick very easily. They are popular since they're cheap. In fact that's one of the reasons why olefin has gained traction - it's a lot cheaper to extrude than nylon which is a
superior fiber to olefin. With an olefin Berber the need to speed dry the carpet and take measures to control wicking is intensified.
As mentioned above, some air-movers will do the trick for a residential carpet. Making some extra "dry passes" will help too. Some post-bonneting can also help. And using an encap detergent will go a long way toward controlling wicking as well. For example
Releasit Encap-
Punch is an encapsulating 3-in-1 detergent that can be used as (1) an Encap Pre-Spray, (2) an Encap HWE Rinse Detergent, and (3) an Encap Bonnet/Pad Detergent.
http://www.excellent-supply.com/Rel...tion-Carpet-Cleaning-Products-Encap_p_69.html
On the other hand - you can use all the tricks in the book and you may still have problems with wicking when you're cleaning a CGD carpet with traditional HWE. There's such a vast difference in the way that residential and commercial carpet responds. Commercial and residential carpet are different animals... especially when it comes to wicking. That's why I made the comments above about there being less of a chance for wicking with a residential carpet. I apologize if my comment came off the wrong way to you.
