Steve Lawrence
Hi all,
We've had to fix this issue before and the typical problem is one of the star shoe supports (springy stainless steel arm) is bent or weak and causes the RX to travel unevenly with a studder kinda. It's usually easy to spot because it doesn't sit evenly when the star is removed and placed on a table.
This time it's not obvious which arm is the culprit. Does anyone know how to located the bad arm when all look okay?
Thanks,
Steve
Thanks,
Steve
