from running a alk cleaner through the TM cleaning grease resturants. I see good results with the PB, and runnig an acid rinse. What if any is there to benefit? Don't know much about using an alk as a rinse. Would some one fill me in. Thanks.
meAt said:BTW, just cause you've been using an acid rinse, that does NOT mean it will re-soil less rapidly either.
it just means the PH is neutral ...PH, in and of it's self has NOTHING to do rapid resoil.
matter of fact, some acid rinses can actually ADD to rapid resoil rates
kolfer1 said:Can you handle it?
kolfer1 said:It is supposed to be for filtration soil. It does not even budge it.
