Y not?
Bob Foster
Here are a couple of scenarios for dual wanding. One to do with vacuum lines and the other to do with solution lines.
Y not run a single 3/8 solution line from the truck to a large work area and then put a Y connector on the line and then plug in two 1/4 solution lines?
Y not run a single 2.5" vacuum from the truck to the work area and then use a Y connector and plug in two 2" vacuum lines?
John Watson
Weren't you the one bitchen about no room on your truck and here you ah go putten more stuff in it. Wowzer, I jest don't understand yous kind from Canadia.. Maybe that last batch of Molsen's had a few extra ice maggets in it.. See youse in Vegas, maybe by the 3rd day I will be able to understand what yer a sayin aye!!
