MORE FLEXIBLE 2 1/2 VAC HOSE?
Ne
I've got 100 feet of this gray 2 1/2 inch vac hose. It's hard to use because it's so stiff.
Is there any 2 1/2 hose available that is real easy to handle and is more flexible?
Fort Worth , Texas
Yes amflex hose 2.5 is way easier to use and becomes a lot more flexible than the other brands.
Olson carries it and cobb carries it as well.
Ne
Can someone post a pic of it?
I think a usplastics.com carries a whole bunch of hose and other stuff too.
Fort Worth , Texas
Easy way to tell if it is Amflex or not, it to look inside the hose. Amflex has a blue liner inside of the hose. This is not fact but I think That liner being smooth inside of he hose makes for an environment with less restriction and flow better vacuum.
Arizona
Ne
Jim that hose looks just as stiff as the grey hose I have. I think I did buy it from Cobb years ago.
Arizona
its not...it is probably some of the best hose i have ever had...light weight and easy to manage...the only thing about it is that you have to remember not to make sharp turns or it will kink...you should always make wide sweeps anyway so it should not be a problem...
I think Lance Golden sell it...Olsen might have it...and I know Joe sells it......
@LanceInAz
Beaumont, Ca
So the big question to John and Larry, what colors do you stock? what colors can you get?
Reactions: Erik
Beaumont, Ca
I was thinking of a green and blue or blue and green. 1 2-1/2" and about 200 feet of 2 inch.
Erik
Michigan
Erik
Joe owns Green. :( This is the response I received when I tried to order green.
Thank you for the request. However any green hose will have to be purchased directly through:
http://nosoupforyou.com/ or realcleaners.com
They are the ones that provide us the color to run these green hoses. If you guys need any other stock color I can help you out
Reactions: Dan
Fort Worth , Texas
My name is money mike so get it right!
We always use 2.5 when possible as it will move the water through the the hose and to the truck the fastest on truck mounts.
On flood kings we just 50-75 ft of 2 inch as that is the port that came on the machine and it worked well.
Jeremy N
Money what are you using on your water losses? 2 inch, 2.5? How much how long a run?
I know that Money Mike already answered but I will give the real answer. What he should have said was - I don't really know what I use. I just close my eyes and reach in the giant pile of tools that I own and pull out whatever ends up in my hand because I have too many tools to choose from.
