Yes, They were yellow and fiared at the ends.Are you talking about the hose guide for pressures hose as you hold in your hand roll a hose up?
The piece you are showing is too small to tell for sure.
Scott, They were made for protecting your hands for the hot solution hose. They had a slot that ran end to end and were flared at the end. Probably 5 or 6 inches long.I'm not sure what that once was. Maybe these to hold the hose off the lawn - https://interlinksupply.com/index.php?item_num=AX193
It is called a "hose boss"Scott, They were made for protecting your hands for the hot solution hose. They had a slot that ran end to end and were flared at the end. Probably 5 or 6 inches long.
That's it, Thanks, Fred. Now were can they be bought???
steambrite was the only industry store I saw it listed atThat's it, Thanks, Fred. Now were can they be bought???
You need to look up "Apology". That sounded nothing like one.Fred probably did it for you
