- Oct 7, 2006
- 12,085
- Name
- Jim Pemberton
Serious question- would putting down some prespray with HF, then using a 175 with brush and shower feed not cut through it better?
One of the problems I always had when I prescrubbed (yes...I go back to the days when a scrubber and a portable was the way to clean...) is that you lay down more fluid, and it takes more skill than I ever learned to control how much you put down.
With shampoo, you could tell by how much foam you saw (a white track, not a pile of shaving cream, was the goal). With prespray, the solution soaks right in and you can't tell how wet you've gotten it.
To be fair, I used mostly portables then, but when we got our first truck mount, I still found it better to prespray and scrub, instead of using the solution tank.
