"Some" old farts ain't got no smarts.
You dumb fookers are going hurt yor old asses.
Not bad deal, 15 student employees, 3 janitors I manage. Janitors keep the building clean, students flip the rooms for the next event.
Boss is very nice and the work is fast paced. We are always running and preparing for the next event.
The only negative has been all the walking but I've even got use to that after a month. [/QUOTE
Walking from your desk to the chocolate bar machine?
You need to consider working out a bit if you're that weak
I'm 62 and toss a 150 pound porty in and out of a van 5 or 6 times a day
You porty guys depress me.
That's a good machine. You will need 20 amps on the cord that powers the pump and vac motors. I have one without heat and converted it to 2 power cords. Works great on small jobs, plenty of vacuum. Eventually I will convert to 2 13.8 vac motors instead of the current 9.8 amp motors. More power is always good. I have a separate inline heater I use with it.I not weak
body hurts more, but still pretty badazz
I'm smArtr than you
AND a better fisherman.
I know you know how to fish ...come on out, and I'll teach you to catch
here's the one I bought today
https://cleveland.craigslist.org/bfs/6639704245.html
opened her up, checked it top to bottom ..all like new
ran it with the heat , all good, no leaks
$750....I own it
..l.t.a.
Actually, I’m headed there tonight. I’m so happy.go hit the Chinese buffet ...you'll feel bedder
..LT.A.
Any crab legs?
You don't know what you're missing until you've had Dungeness crab dipped into hot garlic butter.
I knew a girl like that once. We just called her itchy.He’s at a Chinese buffet.
He probably has crabs and doesn’t know it
Did MeAt get the Mytee?
400$ on ebay. If I have to use a porty...this is the one that will be in the van. Light and easy to use...spot cleaning most likely.
The $3000 dollar Ninja Warrior will stay in the garage...hope I never need it. View attachment 84188
Jack im curious what pump and vac you used as an upgrade on your R-40?I have the EDIC and it great but doesn't go up the stairs easy good for 1 floor units. I just picked up a old original rug dr. R-40 changed out the pump and vac. Now blue in color and use it for furniture and spotting. Make it easy to get through the day. jz
Really wanted the big one with the 16 inch tool but this was what I could find and it is like new. Spent it's life at the Los Angeles City Water and Power Building and looks like it was used a couple of times and put away. Still one day I will pick up the big one.i see you bought that Vibra Vac R-101 with the RE-VB-12B combo
Hi Bob, i got a couple of the bigger R-150's that came with the bigger VB-16B 16 inch wand which weighs like 40lbs. I prefer the 12inch RE-VB-12B, VB-12B or smaller 10inch V-10B myself though.Really wanted the big one with the 16 inch tool but this was what I could find and it is like new. Spent it's life at the Los Angeles City Water and Power Building and looks like it was used a couple of times and put away. Still one day I will pick up the big one.
