CDS & Greenie
Doug Rice
I read a while back that Greenie used to sell some type of bracing for the Hydramaster CDS waste tank. Why and how did it work. Searched but can't find it in old threads.
I sort of recall that or just some sort of aluminum square that kept the tank from caving in on each other when they were poorly made I don't know if there's an issue with the new tanks
but any fabricator should be able to measure that and build you some supports
Village Idiot
Not sure if this is what you are talking about and no pics but
apparently just a picture frame like support that keeps the tank from sucking in and losing seal at the lid allowing for higher lift/less leaks
Doug Rice
Is that a frame that sits vertically supporting the top or does it fit in around the perimeter of each section?
