Village Idiot
- Jul 13, 2011
- 26,413
so now you're back to a porty in a van right?however I would rarely use it in gas mode and choose to use the customers electricity.
unless you run a lot of cords
This machine has to stay in the van. Needs too much juice to roll it into a home.so now you're back to a port in a van right?
That was kind of my pointThis machine has to stay in the van. Needs too much juice to roll it into a home.
This new thing is just a bigger version with twice the motors.
Until it wasn’t...
4 motors (400 CFM and 200” of lift)what is different about it this time?
Do you all hear complaints about Mytee extractors? The Escape has been out for years and I don’t really really hear anything negative. They are basically just making an Escape with 4 motors instead of 2.
The Aurora generator looks top-notch (going off internet info) and isn’t built by Mytee. The HX looks to be just like what is found on Butlers and other direct drive units. The HX also isn’t built by Mytee.
I hope it’s a success because truckmounts are ridiculously priced.
This was out in 20124 motors (400 CFM and 200” of lift)
Aurora generator powered by the truck. Google those generators... they’re used by our military.
A heat exchanger that looks identical to every other direct drive TM.
Being electric doesn’t seem like their selling point.
Being only 15k total and competing with 570s without any maintenance seems like what they’re selling.
Have you seen this machine?Dude...it's got electric vacs and shittons of plastic components
there are no electric vacs comparable to positive displacement blowers
count the beans ..
It's $5000 porty in a $28K van with $5000 in an aftermarket alternator and wiring
and a 200HP van engine that has to run to power and make hot water for a $5000 PLASTIC porty
it's the definition of stoopit when a $12-15K gas TM like a Judstone or TCS will suck that plastic POS into the waste tank
Give me one for a month. I'll find every flaw and weakness.Dude...it's got electric vacs and shittons of plastic components
Me too. I only come here for entertainment now.2nd time this year I've had to run 200ft off my lil 36 blower, which makes it feel like a porty.. until you try the porty
I would like to try the newer Lx vacs or whatever they're called, or hear an unbiased review.. but I'm on the wrong forum
You have the first generation Escape that had 4 of the old, smaller motors.I've had the 4 vac model model for about 4 years now. i think the newer version uses the bigger 2 vac system.
but Larry is correct-- PD blowers are better.
and Yes-- there were problems right on of the box.
By the way, can you finally explain why positive displacement blowers are better?
What??That’s because Mikey can be bought
Was their handle even designed for a 1.5 inch wand?For christ sakes even their cool wand handle slips on a 1.5 regardless of how tight you crank on the bolts
and what moron puts the bolt heads on the outside?
