Attach solution tank hose to deck
Condog
Phoenix AZ
Tony
Missing barbed hollow bolt sits on the deck of a side-by-side, the solution hose runs from the solution tank in fits onto the metal barb and drips the solution onto the pad driver.
Please post where I can purchase the barbed hollow tube.
If possible it's name and size.
For the Centaur Rabbit in the picture.
Village Idiot
I only see it available with the kit although you might be able to get just that piece by contacting Malish. The kit, although 80- $100+, might be worth it to have other spare parts.
Without knowing the size/thread pitch it is hard to direct you to a hollow threaded rod and threaded tube insert to make your own
Reactions: Condog
I only see it available with the kit although you might be able to get just that piece by contacting Malish. The kit, although $100+, might be worth it to have other spare parts.
What is the function of the peice?
