Mike Draper said:
can someone upload that huge list of ridiculous things that need to be checked off daily, weekly, monthly in order to keep the warranty? How much time per month are you spending doing that instead of making money?
DAILY ITEMS
1. Clean recovery tank filter bag
2. Check cat pump oil
3. Check blower oil
4. Check engine oil
WEEKLY ITEMS
1. Clean Recovery Tank Screen
2. Inspect blower belts
3. Inspect cat pump belts
4. Inspect front end belts
5. Clean Detergent filter
6. Inspect hoses
7. Visual leak inspection
Gauge Readings: Record while operating machine normally
Tachometer
Vacuum gauge
Pressure gauge
Temp gauge
Hour meter
Vehicle odometer
MONTHLY ITEMS:
1. Clean inlet water strainer
2. Clean and oil lobes of blower
3. Grease Blower (if applicable)
4. Clean filter screen on wand
5. Clean filter screen on stairtool
6. Grease live vacuum hose swivel
7. Test park interlock system
EVERY 500 HOURS OR 6 MONTHS (minimum every 6 months)
1. Change cat pump oil
2. Change blower oil
3. Check that all nuts and bolts are tight
