joeynbgky
The check oil light is on, oil level is ok. The oil pressure gauge moves back and forth when you press gas pedal. anyone know what this could mean?
DavidB said:Most common problem is the sending unit (sensor) however the oil pump could be bad if the problem persists.
C&S said:have your pressure checked. it could be a bad sensor.. if the van has a ton of miles then i would worry about a oil pump..
