I may have to dig my shear dry out again. I did not like the spray soaking me and everything else in its path due to the spray direction both forward (fine) and backward. The center holes sprayed out too forcefully, so I plugged the back center hole.
I know if I dial down the pressure and flow enough that I will not have that problem. But that reduces cleaning performance.
I wish I felt more comfortable with the shear-dry because it is light and nice to work with in other ways, but I still reach for the Hydrokinetic that uses full pressure and flow. More peace of mind I guess.
I have thought about a slight redesign of the faceplate, but as I wind down I am not motivated enough to play with changing a couple things. Seems like Royovac should be able to do that themselves.
