Here are some pictures of the process. I took 3 days to complete.
Day 1
Demo the ceramic tile
Grind the floor to a 30 grit profile
Put down a moisture barrier epoxy and broadcast sand into it and let it dry over night
Day 2
Sweep up excess sand
Mix overlay 2 bags at a time
Pour onto the sand
Spread with a gauge rake set at 1/2"
Smooth (be sure to wear spike shoes)
Let dry overnight
Day 3
I don't have any pictures of the polishing process because I wasn't there for it.
All polishing must be done dry or else it will be too aggressive for the overlay
Start the polishing process with 50 grit semi metal diamonds
Then 100 grit semi metal
Then 200 grit resin
Apply the acetone dye
Polish with 400 grit resin diamond
Polish with 800 grit resin diamond (optional. This job stopped at 400 grit)
Apply the guard and burnish. Prosoco Polish Guard was used for this job.
If you have any questions, let me know.
