alrighty then. I am positive a company can make a living offering a set price for X amount of rooms. if they do the work themselves and work their butts off. it does not cost hourly to run a carpet cleaner. maybe personal time.
Concidering most hacks were working for micky d's the week before at $150 a week so anyhting more than that is gold to them. jmho..
Even tho chemdry uses a
cds unit it is always been modified by harris research. You will not find a cat pump on that machine. not a standard heat exchanger. you will find a suitorbilt 3.3 blower, two 12 volt shurflo pumps for chemical A and the other for chemical B. one acidic the other is base when mixed viola bubbles. to maintain those refreshing bubbles the heat cannot for any reason go over 160 degrees. So a stainless steel coil is wrapped around the exhaust port to barely heat the water. and yeah I would put down any chemdry that didnt use a tm no matter how it was setup. But. I can still pull out more dirt using my backup porty than their truckmount can pull up. that is a fact.
