Joel D
Mine stopped working. There was a slight crack in the 3 way valve-(prime off on). So i replaced it.
I disconnected the line from the exit side of the chemical pump and it just dribbles. But when hook everything up and put it on prime it primes and i can see fluid going from the chemical tank to the pump.
Also when its disconnected and i turn the valve to on water shoots out coming from main exit line going to wand just behind the panel at the elbow where the last step chemical injection is supposed to be going INTO not OUT OF but there is no check valve stopping it from flowing the wrong way that i can see. (theres a big check valve before the elbow)
That means water pressure is constantly going to the 3way that cant be right.
So anyway i dont understand this at all. What tells the chemical pump to start working when theres no valve or switch except a 3 way AFTER the pump.
If anyone is bored and would like to make me feel dumb-585-993-0276 I can call you back if you want to save phone bill.
