choc milk
glenboy
MACOMB MI
GLEN
customer spilled glass of chocolate milk into carpet....i hit it with an enzyme....dwell.....water claw....then rinsed and extract well.....2 hours later the stains re appear.....HELP......as i dont do these often.....and generally its white milk..
San Francisco, CA
Milk can be difficult to remove if spill is substantial.
  • For the enzyme to work it needs a decent dwell time.
  • If in pad, I doubt the enzyme reached all the way through carpet (+ it is also in glue layer).
  • You can encapsulate or bonnet, but if milk remains in pad, it will start smelling later.
If you can access pad, take care of it, clean carpet from both sides. It would work but be lots of work.
Otherwise give a good dose of enzyme, dwell time, a mini flood and flush with the claw. Follow with lots of dry passes. And if it makes you feel good follow with encapsulation & a bonnet.
I don't think it is a dye stain as it came back.
Hawaii
I'd try the placing something heavy on a cotton towel after you work on it again... I'm with Offy on this one... What color carpet?
Georgia
Oh, sorry. I skip read cuz most post are filled with boring useless trivia on this board.
It might not actually be chocolate. It could be a dye stain.
@Larry Cobb
Moron! Dye stains don't wick back. The spot wicks back up
If it were stained, it would've never went away
