If I see them I hit them with my lighter and push it down back into the spot. It will never run or come loose after that.If you see loose yarn, cut it off and/or glue it back down. If that is not an option, just avoid the spot. A CRB will not pull out a yarn that is bound to the backing but it could further pull one that is already loose. Not common, but it could happen.
