FOJL
- Joined
- Oct 7, 2006
- Messages
- 18,851
- Name
- Lee Stockwell
There is certainly a need for someone to certify "certification bodies" for their authenticity.
Lee Stockwell said:There is certainly a need for someone to certify "certification bodies" for their authenticity.
sweendogg said:Thats because the truck suckkksss sooo hard it creates an eternal black hole!
Shorty Down Under said:What influence is the CRI - SOA going to have overseas in countries like the U.K. & Australia / New Zealand. :?:
Most of our equipment and chemicals are now imported from the USA.
To be honest with you, we laugh at someone that say's they can walk in off the street and hire a "certified SOA" rental machine, (such as a rug doctor), and honestly believe that they are going to do a better job at a cheaper cost than a professional carpet/upholstery cleaner that has years of training and experience in the real world.
How can the CRI justify endorsing rental machines to the general public as "SOA" approved. :?:
Will you be at Connections in Vegas this September. :?:
Regards,
Shortestwun.
:roll:
PS :::: My ex tried to get me certified, but the doctor of the day, ( he also was still practising ), said there was "no hope".![]()
LisaWagnerCRS said:Debbie,
I set aside "quiet time" to read your full paper today - as opposed to the scan I did a few days ago.
I wonder, after you are completed with receiving review comments, and publish the white paper, if you would have any interest of creating a "CRI for Dummies" version that most who are not accustomed to reading scientific papers might benefit from. Perhaps the main points from your summary into bullet points for the "masses" in the cleaning AND retailing world?
I would be happy to help be an interpreter... I speak Dummy fluently since I am one.
Thank you for the very thorough, seemingly unbiased presentation of the "facts."
Lisa
Jim Pemberton said:I would like to talk about your feelings on the soil used, Debbie. I think its part of the foundation of the testing protocol that creates the ability for a Rug Doctor to get listed higher than a truck mount. Am I correct in assuming this?
Ron Werner said:so a good vacuum by itself could have been Gold Certified before an extractor even got turned on?
green research said:[quote="Ron Werner":24ri1vfs]so a good vacuum by itself could have been Gold Certified before an extractor even got turned on?
truckmount girl said:Debbie, isn't a huge problem the allowance of "systems", wherein a company can basically write their own testing protocol which need not have any bearing on the use of said chems/equipment in the field?
Take care,
Lisa
Doc Holliday said:The moisture caused the designer soil to clump and give errors in reading. Is this where it actually read as if it was more soiled after cleaning?
Doc Holliday said:Would a different element read any different or are they just asking too much of the XRF gun?
Doc Holliday said:It just seems that they found the XRF gun and fell in love with the technology before they saw if it was going to give them any results that were useful and valid.
Then once committed they disregarded how ineffective the gun was at reading the designer soil and pushed on. :?
WOW, people can sure get defensive when they get caught doing something they know isn't right.But when confronted with flaws, the responses I get are things like We could have fixed that part but it was a cost/time issue, or "what do you have that's better?" I'd rather have things done right or not at all.
More likely they present a protocol that is very reasonable, testable, and effective. The challenge being that in the field that protocol is never followed. So they get a Gold performance in the lab, but in practice it's barely a Bronze.green research said:For systems, they do have a check in place to prevent a wonky protocol... according to PTL, if they deem a protocol fishy at the lab, then it's sent to a CRI Review Board who is supposed to decide on it.
The subjectivity of the systems testing aside, it could be argued that the extractor testing protocol has little bearing in the field either. Many people with SOA extractors in the field pre-vacuum, use chemistry, agitate somehow, use fans, etc., and thus are not following the testing protocol of doing nothing but using a straight-suction vacuum cleaner followed by 2 plain water passes and 2 dry passes.
Larry Cobb said:(I heard TEN cleaning passes was used by one underpowered manufacturer)
timnelson said:From CRI website:
Mighty Pack® with Rug Doctor Oxy-Steam®
Mighty Pack® with Oxy-Steam® Cleaner solution diluted 4 oz / gl Procedure: Each sample is cleaned using the Rug Doctor 2 step cleaning process. Step 1 - vacuum prior to cleaning at least 4 passes. Step 2 – Hot water extract with Rug Doctor Oxy-Steam® Carpet Cleaner detergent diluted 4 oz per gallon using 4 wet extraction passes at a rate of 1 ft/sec on each pass.
From Rug Doctor website:
Rug Doctor machines are designed to deep-clean and extract in one cleaning pass. Don't go over heavily soiled spots more than 2 times.
