does high flow cleaning also apply to t&G ?
juniorc82
Jefferson City missouri
Jon Coret
I was looking at my spinner tool and it is running 4 flow. I have a northstar diesal/ kero heater running as an auxilary when I clean with my green horn or high flow so it can keep the heat up. I didnt know if it was worth switching my jets up to 6 or 8 flow on the spinner. Most t&G I do is commercial and is trashed so any thing I can do to save time would be awesome.
floorguy
Utah
Doug
you will loose pressure with bigger jets.....
open the hose bigger, and it takes more to keep up the pressure....
make sense??
just more water to suck up and waste.
its not like you're trying to flush 3/4 of an inch deep into the grout or stone..
leave the jetting alone IMO
Fort Worth , Texas
What you will notice is that your vac will not keep up and actually bog smaller blowers downin my experience.
You have to remember that you up the pressure close to 1000 psi to clean tile and now the higher psi will lead to a much higher water output. Like mikey said you will consume a lot of water.
FLYERMAN
West Jordan Utah
Ken Raddon
Go up one jet at a time. Put in just one, say a three flow. Then if you like that put a 4 flow in the other jet. Then you'll know if you want to be six, eight or go back to what it was.
