MB Auctions
- Joined
- Sep 15, 2014
- Messages
- 92
EDIC Portable Spotter Machine w/ Handtool & Hose
This new exciting unit has enough oompf to be able to use with a 10" wand! Amazing 106" water lift in a 3 gallon package! No set up time - simply unload and begin cleaning immediately. Compact size and maneuverability make the Bravo™ ideal for spotting and quick cleaning of small carpeted areas, upholstery and auto interiors. Operators will appreciate the specially designed molded-in holders that carry spray bottles, leaving the hands free. Warranty : 5 years on parts & labor, lifetime on rotationally-molded housing. $710 retail value w/ free shipping! Unique molded-in holders carry spray bottle for greater ease. Large six-inch wheels and a transport handle plus cord wrap assembly make it a snap to wheel about. Quickly opens up for easy servicing and repair. Large porthole
JMA Masterblend Redline Powder Prespray 45#
Jim Martin's fave! The SilverBullet of moderate presprays. no/no odor, water rince-able, boost-able just can't be beat for everyday synthetics with no major pet or grease issues. $168 retail w/ FREE shipping to the Lower 48 RedLine PreSpray Powder Concentrate is a high performance super concentrated powder prespray. Excellent for use on the heaviest soil on commercial-grade and residential carpets. Deep cleans olefin carpets for superior carpet appearance. Reduces cleaning time and post spotting.
6 pack of Duk Brand Corner Guards
The world's Finest Corner Guard, for staircases or just regular ol' flat floor corners are being made available here in this old fashion auction at a nice potential savings. 6 x's $25= $150
MSA Magic Wand Grease Eater 2 times concentrate
You are bidding on a 30lb pail of Magic Wand's most popular and powerful product. Extremely versatile and economical. ONLY ONE OUNCE PER GALLON NEEDED! http://www.magicwandcompany.com/Best-Carpet-Cleaning-Chemical-p/greaseeater.htm Grease Eater is a powerful Prespray with a high pH to clean "trashed" carpets and synthetic furniture. It quickly dissolves stubborn spots and stains so you can easily rinse them away. It decreases your cleaning and spotting time so you can increase your production and income. Here are some key benefits of Grease Eater: 1 to 64 dilution means that only 2 oz will make a ready to use (rtu) gallon. pH of 10 neutralizes the pH faster. Surfactants loosens up the dirt quickly. Citrus (delimonene) dissolves oil based stains like grease and oil. Helps break the oily bond associated with Polyster, Olefin (see a Video ), Triexta and Nylon. Oxygen (hydrogen peroxide) makes organic stains like
$700 CTI Pro's Choice Shopping Spree!
Your choice of ANY Pro's Choice /CTI chemicals, mix and match to your heart's content! Free shipping to the Lower 48! Grab your cart and go shopping HERE
Odorcide, Case of 4 gallons, Fresh or Original
ONE-TIME ODOR ELIMINATION For carpet, locate the source of the odor (a black light or moisture probe may help identify urine deposits) and treat after vacuuming loose dirt and debris. Mix concentrate with water at a rate of 1:16 (8 oz per gallon) and saturate 50% beyond the actual “spot” area. For general carpet deodorizing, add Odorcide® directly to the cleaning extraction system insuring it penetrates to the odor source. Increase penetration by using a roller, hand manipulation or by “walking” the product in. ON-GOING ODOR ELIMINATION Dilute with water or cleaning solution at a rate of ½ oz per gallon.
