Help ventillating a chevy van
I think I need to ventillate my van with a fan. I was thinking about using a small mini air mover. I believe my fuel lines are getting too hot. My machine runs perfect in low, but is not reliable on medium. I replaced the switch and that did not fix anything. Harper said her believes the fuel lines are getting too hot and that theory makes sense after talking to a few other cleaners with Everests and my supplier. How would you set up a fan in a Chevy Van? I could hook it into my AC adapter, but I am affraid the battery on my truck will get drained on a big job. Any suggestions. Really I just need a way to insulate the fuel lines or keep them from overheating.
Shane T
Waukesha, WI
Shane Tiegs
In my last van I mounted a small Stanley turbo fan to the ceiling and ran an extention cord to run it on hot days. It helped to get the heat out of the van.
charles
On real hot days (over 90 degrees) I just plug in one of my air movers with an extension cord to custys home. Makes the van about 20 to 25 degrees cooler.
