Too much OJ imo.
Les put countless hours into development of o2 products working with reps of several chemical companies. I know this because we were one of his main "testers" out in the field. That was quite a few years ago. We use his products as well as others as they work very well for us.
That's strange. We find just the opposite in this area. After normal extraction we've measured almost neutral ph. We have extremely soft water in this area. It has been several years since we have measured ph with this product however. Time to dust off the meter and get to testing.I ain't a blow n go product for sure.
Takes quite a bit to rinse it well, if you don't the re soiling is a bitch
If it is that hard to rinse from carpet with high pressure/high flow, wouldn't it be even more of an issue with upholstery?O2 is Great but it's a pain in the ass to rinse out....
I use it for upholstery only now.....
....of course it is. Don't ya know we suthners do everthin' backerds....If it is that hard to rinse from carpet with high pressure/high flow, wouldn't it be even more of an issue with upholstery?
Or is it different down south?
You know, I've often had the thought that if one was to create a table of people's favorite prespray cross-referenced with their water hardness, predominant local soil type and the cleaning temperature they use that a pattern would emerge....All dirt and all water varies with location.
In my experience all acidic, neutral or lightly alkaline rinses will eventually grow algae, if not used for awhile. Definitely not Judson specific.
The Larry's of the world are so used to 8oz per gallon that they can't force themselves to trust a dilution ratio as low as 2 oz per gallon.
