Let here your thoughts/ experiences with different spot cleaning machines
EDIC
Los Angeles, CA
Rick
Sorry..
85" or 106" water lift on the vac motor?
Damn auto correct/Fill!!
Hi Guys,
The unit that Mikey has is the 300MH-HT. It has a 55PSI pump, 106" of water lift and an 8' hose for easy spotting, but you can run a hose double that length or more easily. It has a 1500watt in-tank heater and weighs in at 19lbs.
<iframe width="640" height="360" src="https://www.youtube.com/embed/L9m5Cotwf20?feature=player_embedded" frameborder="0" allowfullscreen></iframe>
Also, for those that watched the above video, the waste tank is designed to be tilted forward and dumped without having to open up the clean out port on the back. The back port is simply for thorough cleaning, removing fibers etc.
Thanks!
San Francisco, CA.
EDIC-- Is the pull up transport handle included or extra?
I'm confused because your resellers all show the bravo with the handle yet some mention the handle as additional. Also some list the same model as Mikey has but the vac motor is only 85" of lift.
EDIC
Los Angeles, CA
Rick
The unit ships with the handle anytime you order one. At one point, we offered it with and without a handle as an option, strictly by request of some distributors. However requests for no handle eventually became the minority and we decided to just include it with all bravo units.
We only make two models of Bravo now. The 300MH and the 300MH-HT. Both of them come with the powerful 106" water lift vacuum and a 55PSI pump. The 300MH-HT has a heater. We no longer build an 85" version.
You may see a 339MH-HT and that is the most common way the 300MH-HT is sold. The 39 just means it is a kit that includes our 1039 type stainless steel upholstery tool and an 8' hose.
Love that little unit Rick, its worked out really well! :cool::cool:
Glad to hear it! Thanks for the kind words.
