Love me some diaper spinning.
icleancarpetz
Rafael Samson
I’m still not convinced them there pad cleaning machines are any better then a tested tried and true (and faithful) ole Clark 175 swing machine in the right hands.
Looks like a hernia waiting to happen With all them attached gizmos.
Actually, easier to use than a swing machine and with the large wheels, it's easier to get up stairs.
Like Ron says they're easier to use.
With a ramp it's easy to get in and out of vans.
I did 5500 sqft with a crb 175, once.
The next time I used my vibe.
A lot easier.
Reactions: Kenny Hayes
Meter Maid
The Undetective
Dayton,Ohio
Chris
An OP is also faster, because of how it scrubs.
It still use a rotary for smaller areas (commercial) when I need maneuverability.
They are just tools and the more tools the better.
Did you see the 1HP, wheels down, 1 gal sprayer, Odyssey being sent to me to test?
Meter Maid
The Undetective
Dayton,Ohio
Chris
No its not.
175 Same scrub but better maneuverability.
Yes On board spray is convenient and shaves some time but not enough for me spend several grands. Thats insane.
It is not the same. It can be the same, but the rotary needs overlapping passes to hit every side.
No its not.
Have you tested both over a verity of projects?
Or are you in the time honored tradition of Mikey's Board posters, just speculating?
Meter Maid
The Undetective
Dayton,Ohio
Chris
He’s either speculating, or simply making shit up because he doesn’t want to spend money on an OP.
