Master blends R.A.G.E
Josh Almanza
Houston, Tx.
Josh Almanza
Anybody else using this rinse from master blend? It has a nice smell after rinsing the carpet, but the higher ph worries me that it might attract soils and cause resoiling. What are some of the results you guys are getting with this product.
Zee
SoCal jungle
I used a few containers of it 10 years ago....
It left too much white residue on my quick connects (even at less than recommended ratio) which led to a lot of issues with the diesel burner flow switch being stuck on "on" position. If you know what that means you'll understand how dangerous that is!
Flame on full blast....while no water is traveling through the system. Sometimes you can hear the diesel burner rumble with the wand laying on the carpet unused.... So you run out to the truck and the pressure gauge is already climbing over 2000psi....!!
It's really a bad design....but I digress.
Rage -in my opinion- is pointless, when you're using a decent prespray and prescrub.
Reactions: Josh Almanza
Ne
A high PH has nothing to do with resoil and residue. It's all in the formulation. I personally use a liquid as my emulsifier or when I use a acid rinse.
