Mikey's Fest Pet Benefit Florida Prize List
davegillfishing
st augustine fla
dave gill
i am already saving my raffle money...i love me a good raffle..its usually fishing stuff but these toys will work lol..and what a great cause..i work with these girls saving animals here in jax and they put a huge dent
in the kill shelters for sure!!
dgardner
Phoenix, AZ
Dan Gardner
Dave Gill has suggested that the funds created from this raffle go to this organization..
https://www.facebook.com/pages/Anas-Angels-Animal-Rescue/303599723033905
Seems like a very worthy cause.
Reactions: Lee Stockwell
added:
Butler 14" 5 jet SS carpet wand
  • The Butler 14" and 18" double bend floor wands feature a slanted head height of 31/4", allowing wands to reach and extend easily under furniture
  • Stainless steel construction
  • Mid-range 14" 5-jet floor wand designed for use on residential and commercial carpet. Improves productivity by an estimated 50%
  • Extra large 18" 5-jet floor wand designed for use on commercial-grade carpet only. Improves productivity by an estimated 75%
  • 5 stainless steel jets precision mounted on a machined stainless steel mani- fold 17/8" from carpeted surface (hot water and pressure are concentrated at optimum height and position from carpet for superior cleaning results)
  • Spray shield to maximize heat concentration and help prevent high pressure splashback on hard surface floors
  • Stainless steel valve assembly with stainless steel plunger
  • Stainless steel formed trigger with black nylon coating
  • Stainless steel adjustable handle with black nylon coating
  • 1/8" stainless steel, contour fit, high-pressure tubing from valve to manifold
  • Padded wand tube cuff for a sure and comfortable grip
  • Remote water filter located at inlet of valve for ease of periodic cleaning
  • Brass female quick disconnect
  • No adjustment required to the Butler System
  • Ultra Smooth Wand Glide allows wand to glide easily over carpet, tile and all hard surface flooring
  • $895 Value
Thanks Butler!!!!
Reactions: Mark Saiger
Just added
d2.gif Illuminates Urine Deposits
Works in High Room Illumination.
New Hi-Power UV Light Source Selected for Best Fluorescence on Urine Stains.
d2.gif Enhances Oxidizers for Stain Removal.
Compact Size - 7.5" x 2" Weight - 8 ounces
2 Hour Operation w/Hi-Capacity
Rechargeable Lithium-Ion Battery
2hr AC Quick-Charger - 110-220 VAC
#GG8BL - $239.95 with
Charger & Belt Nylon Case
just added!
Odorcide Starter kits (4) $200
ODORCIDE® CONCENTRATE
Refer to dilution instructions outlined below to calculate the necessary amount of concentrate needed. Always plan to apply in a manner most conducive to getting Odorcide to the source of the odor. Odorcide will always work best when applied to a dry surface. This will ensure Odorcide is able to penetrate to the odor source. Odorcide may also be used as a laundry additive or in a fogger.
DILUTION INSTRUCTIONS:
• For serious, deeply imbedded odors; dilute 8oz per gallon of water (1:16).
• For milder odors; dilute 2-4oz per gallon of water (1:32-64).
• For topical or general ongoing deodorization; dilute 1/2oz per gallon of water (1:256).
• For organic decomposition; dilute 8oz per gallon of water (1:16).
Reapply as needed.
ODORCIDE® READY-TO-USE SOAKER
Pull up cap, point at odor site, squeeze. If deeply embedded, area must be thoroughly saturated. (Stepping on the soaked area will improve penetration once Odorcide has been applied.) Odorcide must come in contact with the odor source to be completely effective. Let air dry. If odor remains, not enough product was used, or direct contact was not made. Repeat.
You have to go to the event.
If works like the last one, you buy tickets that are then dropped in the boxes for the items that you are interested in. At the end of the show they draw from the boxes and give out the prizes.
Its nutz, for a few bucks you can win fantastic prizes. :cool:
