Mytee Spinner issue???
floorguy
Utah
Doug
sooooo I am not getting hardly any pressure at the wand...
I have already checked all the lines....i put a lance at the end and it sprayed hard.....spinner...ehhh not so much
I dont use it a ton, but it has been fine for a while.....one job it worked fine, and then i let go of the trigger and it acted up, at the end of the job???
Realized it was the couplings then (had heater debris in them)
so i used it a few weeks ago, fine nothing wrong...
went to use it today...bleh...barely pissed through the job.....
soooooo no hose or machine issues
so where do i start on the tool???
floorguy
Utah
Doug
nooo, mine is the wand style (older)
I have looked in the back end :shock: :shock: :oops: :oops:
and there is no screen i can see
floorguy
Utah
Doug
yup i went and looked for mine.....thanks
but still no mesh....
wonder if an o ring in the handle went to shit???
GeneMiller
Boca Raton
gene miller
Definitely start at the jets , remove and give a good blast to clean out any debri. then install a screen because those little jets need them.
gene
Shane T
Waukesha, WI
Shane Tiegs
Replace the complete inline filter. A while back I had one act up. I cleaned it without effect. When I replaced it I never had another problem.
floorguy
Utah
Doug
hummmm this sounds like it could be the case....maybe ill take it out 1st and see what it does then...
then jets, then swivel....
