NEW CTI PRODUCT! OS-1
Discussion in 'the CleAn Room' started by CTI Courtney, Jun 2, 2017.
By CTI Courtney on Jun 2, 2017 at 12:36 PM
  1. CTI Courtney
    CTI Courtney
    Jul 9, 2015
    96
    Rancho Cordova , CA
    Name:
    Courtney Rodseth
    Hi all!
    I am happy to announce that we have released a great new product called OS-1. It is a ready to use, all in one, high performance Odor and Stain remover. It is basically a pre-mixed, liquid version of OSR, and is a great solution for low moisture cleaning.
    Samples are available by request at your local distributor.
    Here is more information on OS-1:
    We are excited to introduce OS-1, an all-in one, ready to use, high performance odor eliminator with built-in stain and soil removal. OS-1 integrates the power of natural oxygen release with the biological power of odor modification and encapsulation to destroy odors, while cleaning agents break down oils and soil for easy removal.
    DIRECTIONS: OS-1 will eliminate odors on contact. For best results, apply OS-1 in sufficient quantity to reach not only the visible surface contamination but also all sub-surface contamination. Agitate the area gently but thoroughly, then blot or extract away the soil. If extraction method is employed, use a Mist-and-Vac technique to minimize the diluting of your OS-1 with water. Make a second light topical application of OS-1 to the area and allow to dry. Any stains not removed by the cleaning will disappear as the spot dries.
    Part number: 2175
    MSRP: $19.95 per gallon
    TConway, SamIam and Lee Stockwell like this.
Comments
Share This Page
