newbie needed advice
Discussion in 'Water, Fire, & Smoke Damage' started by David S, Mar 22, 2018.
  1. David S
    David S
    Mar 22, 2018
    7
    Southern ontario
    Name:
    David Spence
    what are the bare essentials equipment needed to start off it water restoration? I know i can add equipment as i go along but what do i need to get started?
    your advice is greatly appreciated
  2. Swani
    Swani
    Oct 25, 2016
    523
    Montana
    Name:
    Nick
    You need to see @Matt Wood post in Mikey's post about adding services.
    David S likes this.
  3. Desk Jockey
    55,817
    a planet far far away
    Name:
    Mr Misunderstood
    Look on Craigslist and see what you can find cheap. Buy new as you grow and keep the used as overflow.
    Residential, a couple of dehumidifiers (lgr) 6-8 airmovers, water claw, moisture meters. A thermal camera if you have the budget.
    David S and Nomad74 like this.
  4. scottw
    scottw
    Oct 16, 2006
    2,616
    West Jordan, UT
    Name:
    Scott Warrington
    Know your market. Starting with small homes? Large homes in your area? Going after commercial?
    I started with residential only. Typical home was 1200 - 2000 sq. ft.
    Truckmount and Water Claw or other extraction tools
    2 medium LGR type dehus
    12 air movers - mostly centrifugal but some radial as well
    Training classes - WRT, ASD and something to help you market. Maybe the Restoration Strategies Turbocharged class or Build a Better Business; Sooner or later Strategies for Sucess.
    Meters including hygrometer, pinless and pin type meters of good or better quality
    Thermal camera if you can afford it.
    Package can be $10,000 to $20,000 if you already have the truckmount; considerably more if you need the truckmount.
    Money for marketing or at least a lot of time devoted to marketing. Most areas are rather heavy with competition.
    David S and Desk Jockey like this.
  5. Nomad74
    4,218
    Redding
    Name:
    Damon
    Check your local laws. Do you need a contractors license?
  6. David S
    David S
    Mar 22, 2018
    7
    Southern ontario
    Name:
    David Spence
    Thank
  7. David S
    David S
    Mar 22, 2018
    7
    Southern ontario
    Name:
    David Spence
    Thanks a lot. What about a water extractor? Just a decent hepa wet/dry shop vac?
  8. Desk Jockey
    55,817
    Name:
    Mr Misunderstood
    You need auto pump-out capable. Flood Guzzler, Flood King, Drieaz HVE 3000 are all great portable extractors.
    scottw likes this.
  9. David S
    David S
    Mar 22, 2018
    7
    Southern ontario
    Name:
    David Spence
    Than
    Thank you Scott. I do have my IICRC Fire and smoke and IICRC WRT. I'm looking at equipment arm so your advice is really helpful. I'm sue I'll be asking more questions A LOT!
    Thanks
  10. David S
    David S
    Mar 22, 2018
    7
    Southern ontario
    Name:
    David Spence
    I was looking at a nilfisk alto attic 50 wet/dry hepa from safety express. Hope that's sufficient.
    Thanks again.
  11. Desk Jockey
    55,817
    Name:
    Mr Misunderstood
    If it doesn't have auto pump out ability, you need to pass. You can easily run into 50-60 100 gallons or more. Stopping to dump can be very inefficient.
    You need the productivity of the auto pump out to make money.
  12. hogjowl
    Feb 19, 2007
    26,690
    Prattville, Alabama
    Name:
    Marty Sutley
    You’ll need dependable help
    Give up now
  13. Desk Jockey
    55,817
    Name:
    Mr Misunderstood
    lol
  14. David S
    David S
    Mar 22, 2018
    7
    Southern ontario
    Name:
    David Spence
    I
    will look in to see if it has an auto pump out. Thanks
    Jimmy L and Desk Jockey like this.
Share This Page
