As memory serves, the default jetting is a total of 06 on a Bentley, likely the exact same total flow as your current 2 jet
TCS wand.
Any dealer selling you that Bentley should have inquired what machine you might be using it with, and possibly offer you a jet change.
You may want to bump your flow a bit since I recall you run a #4 LG heater, you will have no problem supporting #2s all the way across, or even #3s all the way across, you just have to decide do you want 240 deg and 08 flow or 210 deg and 012 flow?
Both will use your #4 heater more efficiently than your current 400 psi and 06 flow.
