Question about Unloader
BLewis
Lexington
Billy Lewis
Called my contact at Interlink because I was having problems out of my unloaded on my Vortex. He suggested to go to a powerwash shop and buy one. I did so and replaced it however the new one is very hard to adjust. When I try to dial it in to 750 psi if I go a slight bit higher it will load up and the pressure will shoot to 2500+. So I will not be able to adjust it for turbo cleaning. I will get a new one (to properly match) from Aerotech Monday but that will take a few days to get here. Numbers stamped on sides are different but all the in/out were match up properly. Is there something I may be overlooking?
Old one 15-04 white spring 250 BAR, new one 09-12 blue spring 280 BAR
BLewis
Lexington
Billy Lewis
Fred that could be. Distributor mentioned something about a "bullet" looking thingy somewhere that may need to be taken out. Where would I find the check value? They were closed by the time I was able to install it this afternoon.
Village Idiot
Jim had a pic in the thread I linked to
BLewis
Lexington
Billy Lewis
Ha Fred I just seen your link! I'll dig into that in the am, I'm sure that will be the issue. Thanks, Fred & Jim
BLewis
Lexington
Billy Lewis
Found it, removed it. Has blue spring should I replace with the white one off the original?
Arizona
blue should be fine...its just a stiffer spring...
Noidios
Anderson, SC
Russ Zinck
What is the reasoning behind removing the check valve?
and while we are at it - which O-ring am I supposed to be lubing every so often? and what am I supposed to be lubing it with?
