mirf
I have a white magic 1200 and never had a problem. We do not use the Quick connects in the front because the solution hose reel is connected to the unit. The wrapped hose stays hot always.
I do have a port but mostly use it in bad areas for security. I think you may have the supply hose from the tank resting directly on the floor and iceing up sending some frozen water to the pump or blocking it altogether. We stopped working when it is that cold and do not go out over 95degrees.
Every year older I get the narrower the operating range gets. My wife and I would drive 1 hour to a restaurant any longer either.
