Raffle! Clean FreAk 2800CFM Turbo Fan up for grabs!
Up for grabs is a genuine Clean FreAk 2800 CFM Air Mover
When you need a lot of air moving capacity this CleanFreak air mover is for you. The simple and durable design allows you to easily carry and stack this blower, so you can handle multiple air movers around your job site. Wrap the cord around the handle for storage and transport. Aim the blower in one of 4 angles to get just the right position to rapidly dry your floor, walls, or ceiling. This generous 2800 CFM blower only draws 5 amps of power, making it easy on your electrical system. ETL certification assures you this air mover has been laboratory tested and is safe for everyday use.
Please note: this blower cannot be daisy-chained to other blowers, but can only be used individually like any major appliance. You can, however, plug multiple units into a circuit protector, since each unit only pulls 5 amps.
For more options, including models that are sold individually, please take a look at our full line of carpet dryers.
Features:
· Low amp draw with high air flow.
· Easily cleaned air filter system (optional).
· Four directions for blowing allow you to aim this air movers in different directions for drying carpets, walls and ceilings.
· Durable design allows for easy carrying and stacking (air movers should not be stacked during transport).
· 3 speed settings with a maximum speed of 2800 CFM from a 1/2 HP motor.
· ETL and C-ETL ratings certify that this unit is safe for continuous use in any facility in the U.S. or Canada.
· 1 year warranty on the housing, and 1 year on parts.
Specifications:
Construction: Injection molded polypropylene
Blowing Positions: 4 (0°, 20° with kickstand down, 45° & 90°)
Motor: 1/2 HP
Speeds: 3
Electrical Use: 115 Volts, 60 Hz
Electrical Draw: 5.0 amps
RPM: 1000 CFM / 1250 RPM / 1500 RPM
Air Flow: 2800 CFM (on high)
Power Cord: 20 ft.
Dimensions: 16.3" H x 15.9" L x 15.7" W
Weight: 19 lbs.
Warranty: 1 year on housing / 1 year on motor
View Details & Register
