Charity Raffle Ronald McDonald Scottsdale Auction #2- Butler Filter Box
  • Positioned in-line between the vacuum hose reels (if so equipped) and the recovery tank
  • Filters debris before recovered water enters the recovery tank
  • Non-restrictive air flow design with either Butler Standard Vacuum/Blower System or optional Butler Maximum Vacuum/Blower System
  • Easily accessible, eliminates need to remove recovery tank lid to empty and clean filter bag(s)
  • May be used with or without live vacuum hose reels
  • Removable and reusable nylon filter bag(s)
  • Dual-wand fittings included
  • Easy-open latch mechanism
  • Single-Bag System: 10 1/2"W x 10 1/2"D x 17"H
  • Slide out mounting brackets for ease of periodic cleaning
  • Stainless steel construction
  • Silver texture finish
All proceeds from this auction go 100% to RMHC.
Payable by check only, made to out to Ronald McDonald House Phoenix
Serious bidders only. Prizes will be sent out directly (at no charge unless noted, from the donor once you check has been received by me.
Opening bid is $350 w/ minimum $20 increments
Retail is $750
Free shipping to the lower 48
Auction is over September 10th at 6PM PST, highest bid wins at 6PM sharp.
