Sapphire Savant
I was blown away when I saw how Sapphire Scientific’s Hard Surface Cleaning System, using high-pressure truckmounts, hot water and purpose-designed chemicals, makes short work of cleaning virtually any kind of hard surface. In fact, from 1000 to 2000 square feet per hour – now that’s moving!
Naturally, ceramic tile is a given, but what if you had to clean thousands of grout lines in a floor of 1” square ceramic tiles? That's the real challenge. How about “digging the dirt” out of Travertine and Terrazzo flooring or, even more challenging, exposed aggregate flooring.
Have you ever tried cleaning painted brick and block walls and concrete surfaces with a pressure washer . . . a good chance of "good-bye paint," right? Not so with Sapphire’s Hard Surface Cleaning System. You get all the grime and leave the paint. And, if you've ever experienced the pain of cleaning and stripping a VCT floor, you didn't do it in one pass with the Sapphire System, and left the floor instantly dry for recoating, at that! Talk about productivity!
You think this is just a bunch of marketing hyperbole? Well, check it out for yourself, right here and now.
http://www.youtube.com/watch?v=DiVmJjtMI-4&feature=em-uploademail-new
And, then go here http://www.sapphirescientific.com/ to check out the stuff – equipment and chemicals – that will put you ahead of your competition.
