I have a boost auto scrubber which has the square head
the machine won't create dust because you will put water on the floor and use the maroon pad to scrub with, it doesn't throw slurry around like a rotary does
it basically is a square pad op machine, you can buy bonnets for it also
Not sure how easy it would move across the carpet
they say the machine will strip wax but it really doesn't, it does remove a few coats of finish though and the pads can be costly
they machine can also be fitted with a vacuum for dustless screening, this type of machine has been around for quite a while
thought process behind using it for stripping is, they feel/scare tactic, that eventualy chemical stripping a vct floor will be a thing of the past
Lee is more right then wrong, what was old is now new again
not sure how you are going to cut labor costs, chemical costs yes but you will use a ton more maroon pads
